Species: Hem-Fir
Grade: HF No.2
Size: 4 x 6
Design Span (L): 3.75 ft.
Clear Span: 3.50 ft.
Total Span: 4.00 ft.
Live Load: 600 plf
Dead Load: 60 plf
Selfweight: 15.5 lbs
Dist. Selfweight: 4.14 plf
Total Weight: 16.6 lbs
Incised Lumber: Yes
Beam Design 2021A598
10/11/2021 1
G = 0.43
10/11/2021 2
= 30.99 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (45.00 + 3)] x (12 in./ft.)3 = 0.53 ft3
Volumespan = N[A x L] = 1 x [19.25 x 45.00] x (12 in./ft.)3 = 0.50 ft3
Total Weight (WT) = ρw x Volumetotal = 30.99 x 0.53 = 16.6 lbs
Self Weight (WS) = ρw x Volumespan = 30.99 x 0.50 = 15.5 lbs
Distributed Self Weight (ws) = = 4.14 plf
600 plf
60 plf
ws = 4.14 plf
3.75 ft.
3.50 ft.
4.00 ft.
1328.28 lbs
1328.28 lbs
10/11/2021 3
Fbx' = (850)(1.00)(1)(1)(1)(1.3)(0.8)(1.15) = 1016.6 psi
fb = = 793.9 psi
 fb = 793.9 psi < Fbx' = 1016.6 psi  (CSI = 0.78)   ➜  OK
10/11/2021 4
Fvx' = (150)(1.00)(0.97)(1)(0.8) = 116.40 psi
fv* = = 73.31 psi
 fv* = 73.31 psi < Fvx' = 116.40 psi  (CSI = 0.63)   ➜  OK
fv = = 97.03 psi
 fv = 97.03 psi < Fvx' = 116.40 psi  (CSI = 0.83)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1300000(0.9)(1)(0.95) = 1111500 psi
10/11/2021 5
ΔLL = = 0.05 in.
(L/d)LL = 45.00 / 0.05 = 909
 ΔLL = 0.05 in = L/909 < L/360   ➜  OK
ΔTL = = 0.05 in.
(L/d)TL = 45.00 / 0.05 = 821
 ΔTL = 0.05 in = L/821 < L/240   ➜  OK
fc⊥ = = 126.5 psi
 fc⊥ = 126.5 psi < Fc⊥x' = 271.35 psi  (CSI = 0.47)   ➜  OK
10/11/2021 6
