Beam Design - Beam Design -Span 1
Size: 3.5 x 18
Design Span (L): 14.75 ft.
Clear Span: 14.50 ft.
Total Span: 15.00 ft.
Live Load: 300 plf
Dead Load: 300 plf
Selfweight: 217.9 lbs
Dist. Selfweight: 14.77 plf
Total Weight: 221.6 lbs
Notes: this only calculates for distributed load - with point load from span 2 - max moment is 33,600 lb*ft - design for bending
Beam Design Braun 1100 Ballarat 1100 Ballarat
10/11/2021 1
d = 18.000 in.
A = 3.500 x 18.000 = 63.00 in.2
Sx = (3.500)(18.000)2/6 = 189.00 in.3
Sy = (3.500)2(18.000)/6 = 36.75 in.3
Ix = (3.500)(18.000)3/12 = 1701.00 in.4
Iy = (3.500)3(18.000)/12 = 64.31 in.4
10/11/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [63.00 x (177.00 + 3)] x (12 in./ft.)3 = 6.56 ft3
Volumespan = N[A x L] = 1 x [63.00 x 177.00] x (12 in./ft.)3 = 6.45 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 6.56 = 221.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 6.45 = 217.9 lbs
Distributed Self Weight (ws) = = 14.77 plf
300 plf
300 plf
  ws = 14.77 plf
14.75 ft.
14.50 ft.
15.00 ft.
4610.78 lbs
4610.78 lbs
10/11/2021 3
fb = = 1061.5 psi
 fb = 1061.5 psi < Fbx' = 2400.0 psi  (CSI = 0.44)   ➜  OK
10/11/2021 4
fv* = = 85.99 psi
 fv* = 85.99 psi < Fvx' = 265.00 psi  (CSI = 0.32)   ➜  OK
fv = = 107.95 psi
 fv = 107.95 psi < Fvx' = 265.00 psi  (CSI = 0.41)   ➜  OK
10/11/2021 5
ΔLL = = 0.10 in.
(L/d)LL = 177.00 / 0.10 = 1696
 ΔLL = 0.10 in = L/1696 < L/360   ➜  OK
ΔTL = = 0.21 in.
(L/d)TL = 177.00 / 0.21 = 828
 ΔTL = 0.21 in = L/828 < L/240   ➜  OK
fc⊥ = = 439.1 psi
 fc⊥ = 439.1 psi < Fc⊥x' = 650.00 psi  (CSI = 0.68)   ➜  OK
10/11/2021 6
