Beam Design - Span 2
Size: 3.5 x 12
Design Span (L): 11.25 ft.
Clear Span: 11.00 ft.
Total Span: 11.50 ft.
Live Load: 500 plf
Dead Load: 500 plf
Selfweight: 110.8 lbs
Dist. Selfweight: 9.85 plf
Total Weight: 113.2 lbs
Beam Design Braun 1100 Ballarat 1100 Ballarat
10/11/2021 1
10/11/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [42.00 x (135.00 + 3)] x (12 in./ft.)3 = 3.35 ft3
Volumespan = N[A x L] = 1 x [42.00 x 135.00] x (12 in./ft.)3 = 3.28 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.35 = 113.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.28 = 110.8 lbs
500 plf
500 plf
  ws = 9.85 plf
11.25 ft.
11.00 ft.
5806.62 lbs
5806.62 lbs
10/11/2021 3
fb = = 2282.3 psi
 fb = 2282.3 psi < Fbx' = 2400.0 psi  (CSI = 0.95)   ➜  OK
10/11/2021 4
fv* = = 166.81 psi
 fv* = 166.81 psi < Fvx' = 265.00 psi  (CSI = 0.63)   ➜  OK
fv = = 202.87 psi
 fv = 202.87 psi < Fvx' = 265.00 psi  (CSI = 0.77)   ➜  OK
10/11/2021 5
ΔLL = = 0.20 in.
(L/d)LL = 135.00 / 0.20 = 680
 ΔLL = 0.20 in = L/680 < L/360   ➜  OK
ΔTL = = 0.40 in.
(L/d)TL = 135.00 / 0.40 = 337
 ΔTL = 0.40 in = L/337 < L/240   ➜  OK
fc⊥ = = 553.0 psi
 fc⊥ = 553.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.85)   ➜  OK
10/11/2021 6
