Grade: 24F-V8 1.8E SP/SP
Size: 5.5 x 15.125
Design Span (L): 25.75 ft.
Clear Span: 25.50 ft.
Total Span: 26.00 ft.
Live Load: 286 plf
Dead Load: 143 plf
Selfweight: 548.8 lbs
Dist. Selfweight: 21.31 plf
Total Weight: 554.1 lbs
CV Volume Factor 0.975b - - - - -
Beam Design 2021A594
10/11/2021 1
d = 15.125 in.
A = 5.500 x 15.125 = 83.19 in.2
Sx = (5.500)(15.125)2/6 = 209.70 in.3
Sy = (5.500)2(15.125)/6 = 76.26 in.3
Ix = (5.500)(15.125)3/12 = 1585.87 in.4
Iy = (5.500)3(15.125)/12 = 209.70 in.4
10/11/2021 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [83.19 x (309.00 + 3)] x (12 in./ft.)3 = 15.02 ft3
Volumespan = N[A x L] = 1 x [83.19 x 309.00] x (12 in./ft.)3 = 14.88 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 15.02 = 554.1 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 14.88 = 548.8 lbs
Distributed Self Weight (ws) = = 21.31 plf
286 plf
143 plf
  ws = 21.31 plf
25.75 ft.
25.50 ft.
26.00 ft.
5854.04 lbs
5854.04 lbs
10/11/2021 3
CV = = 0.975
CV = 0.975 < CL = 1
Fbx' = (2400)(1.00)(1)(1)(0.975) = 2340.0 psi
fb = = 2135.8 psi
 fb = 2135.8 psi < Fbx' = 2340.0 psi  (CSI = 0.91)   ➜  OK
10/11/2021 4
fv* = = 94.31 psi
 fv* = 94.31 psi < Fvx' = 300.00 psi  (CSI = 0.31)   ➜  OK
fv = = 104.54 psi
 fv = 104.54 psi < Fvx' = 300.00 psi  (CSI = 0.35)   ➜  OK
10/11/2021 5
ΔLL = = 0.99 in.
(L/d)LL = 309.00 / 0.99 = 312
 ΔLL = 0.99 in = L/312 < L/180   ➜  OK
ΔTL = = 1.56 in.
(L/d)TL = 309.00 / 1.56 = 198
 ΔTL = 1.56 in = L/198 < L/120   ➜  OK
fc⊥ = = 354.8 psi
 fc⊥ = 354.8 psi < Fc⊥x' = 740.00 psi  (CSI = 0.48)   ➜  OK
10/11/2021 6
