Size: 3.5 x 9
Design Span (L): 18.75 ft.
Clear Span: 18.50 ft.
Total Span: 19.00 ft.
Selfweight: 138.5 lbs
Dist. Selfweight: 7.39 plf
Total Weight: 140.3 lbs
Beam Design 2021A590
10/10/2021 1
d = 9.000 in.
10/10/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [31.50 x (225.00 + 3)] x (12 in./ft.)3 = 4.16 ft3
Volumespan = N[A x L] = 1 x [31.50 x 225.00] x (12 in./ft.)3 = 4.10 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 4.16 = 140.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 4.10 = 138.5 lbs
  ws = 7.39 plf
18.75 ft.
18.50 ft.
19.00 ft.
1732.66 lbs
1732.66 lbs
10/10/2021 3
fb = = 2035.5 psi
 fb = 2035.5 psi < Fbx' = 2760.0 psi  (CSI = 0.74)   ➜  OK
10/10/2021 4
fv* = = 74.91 psi
 fv* = 74.91 psi < Fvx' = 304.75 psi  (CSI = 0.25)   ➜  OK
fv = = 81.42 psi
 fv = 81.42 psi < Fvx' = 304.75 psi  (CSI = 0.27)   ➜  OK
10/10/2021 5
ΔLL = = 0.73 in.
(L/d)LL = 225.00 / 0.73 = 310
 ΔLL = 0.73 in = L/310 < L/180   ➜  OK
ΔTL = = 1.33 in.
(L/d)TL = 225.00 / 1.33 = 170
 ΔTL = 1.33 in = L/170 < L/120   ➜  OK
fc⊥ = = 165.0 psi
 fc⊥ = 165.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.25)   ➜  OK
10/10/2021 6
