Grade: DF No.1 & Btr
Size: 4 x 12
Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 250 plf
Selfweight: 128.6 lbs
Dist. Selfweight: 9.35 plf
Total Weight: 130.9 lbs
CF Size Factor 1.1 1 - 1 - -
Beam Design 2021A589
10/8/2021 1
10/8/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (165.00 + 3)] x (12 in./ft.)3 = 3.83 ft3
Volumespan = N[A x L] = 1 x [39.38 x 165.00] x (12 in./ft.)3 = 3.76 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.83 = 130.9 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.76 = 128.6 lbs
250 plf
ws = 9.35 plf
13.75 ft.
13.50 ft.
2340.47 lbs
2340.47 lbs
10/8/2021 3
lu/d = = 2.13
Rb = = 6.74
 Rb = 6.74 < 50   ➜  OK
10/8/2021 4
Eminy' = Eminy(CM)(Ct)(Ci) = 660000(1)(1)(1) = 660000 psi
FbE = = 17443.37 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1200)(1.15)(1)(1)(1.1)(1)(1) = 1518.00 psi
CL =   = 0.995
Fbx' = (1200)(1.15)(1)(1)(0.995)(1.1)(1)(1) = 1510.8 psi
fb = = 1284.3 psi
 fb = 1284.3 psi < Fbx' = 1510.8 psi  (CSI = 0.85)   ➜  OK
fv* = = 75.63 psi
 fv* = 75.63 psi < Fvx' = 207.00 psi  (CSI = 0.37)   ➜  OK
fv = = 87.57 psi
 fv = 87.57 psi < Fvx' = 207.00 psi  (CSI = 0.42)   ➜  OK
10/8/2021 5
ΔLL = = 0.27 in.
(L/d)LL = 165.00 / 0.27 = 613
 ΔLL = 0.27 in = L/613 < L/360   ➜  OK
ΔTL = = 0.36 in.
(L/d)TL = 165.00 / 0.36 = 459
 ΔTL = 0.36 in = L/459 < L/240   ➜  OK
fc⊥ = = 222.9 psi
 fc⊥ = 222.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.36)   ➜  OK
10/8/2021 6
