Beam Design - TEST
Size: 4 x 12
Design Span (L): 15.00 ft.
Clear Span: 14.75 ft.
Total Span: 15.25 ft.
Live Load: 20 plf
Dead Load: 10 plf
Selfweight: 140.3 lbs
Dist. Selfweight: 9.35 plf
Total Weight: 142.6 lbs
Notes: TEST
CF Size Factor 1.1 1 - 1 - -
Beam Design TEST TEST TEST 000
10/7/2021 1
10/7/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (180.00 + 3)] x (12 in./ft.)3 = 4.17 ft3
Volumespan = N[A x L] = 1 x [39.38 x 180.00] x (12 in./ft.)3 = 4.10 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.17 = 142.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 4.10 = 140.3 lbs
20 plf
10 plf
ws = 9.35 plf
15.00 ft.
14.75 ft.
15.25 ft.
300.06 lbs
300.06 lbs
10/7/2021 3
Fbx' = (900)(1.00)(1)(0.8)(1)(1.1)(1)(1) = 792.0 psi
fb = = 179.9 psi
 fb = 179.9 psi < Fbx' = 792.0 psi  (CSI = 0.23)   ➜  OK
10/7/2021 4
Fvx' = (180)(1.00)(1)(0.8)(1) = 144.00 psi
fv* = = 9.84 psi
 fv* = 9.84 psi < Fvx' = 144.00 psi  (CSI = 0.07)   ➜  OK
fv = = 11.24 psi
 fv = 11.24 psi < Fvx' = 144.00 psi  (CSI = 0.08)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1600000(1)(0.9)(1) = 1440000 psi
10/7/2021 5
ΔLL = = 0.04 in.
(L/d)LL = 180.00 / 0.04 = 4725
 ΔLL = 0.04 in = L/4725 < L/360   ➜  OK
ΔTL = = 0.07 in.
(L/d)TL = 180.00 / 0.07 = 2401
 ΔTL = 0.07 in = L/2401 < L/240   ➜  OK
fc⊥ = = 28.6 psi
 fc⊥ = 28.6 psi < Fc⊥x' = 500.00 psi  (CSI = 0.06)   ➜  OK
10/7/2021 6
