Grade: SP DSS
Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Selfweight: 175.7 lbs
Dist. Selfweight: 11.15 plf
Total Weight: 178.4 lbs
Ct Temperature Factor 0.7 0.9 0.7 0.7 0.7 0.9
Beam Design 2021A579
10/5/2021 1
10/5/2021 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (189.00 + 3)] x (12 in./ft.)3 = 4.63 ft3
Volumespan = N[A x L] = 3 x [13.88 x 189.00] x (12 in./ft.)3 = 4.55 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 4.63 = 178.4 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 4.55 = 175.7 lbs
Distributed Self Weight (ws) = = 11.15 plf
ws = 11.15 plf
15.75 ft.
15.50 ft.
1489.22 lbs
1489.22 lbs
10/5/2021 3
Fbx' = (1950)(1.15)(0.85)(0.7)(1)(1)(1)(1) = 1334.3 psi
fb = = 1079.4 psi
 fb = 1079.4 psi < Fbx' = 1334.3 psi  (CSI = 0.81)   ➜  OK
10/5/2021 4
Fvx' = (175)(1.15)(0.97)(0.7)(1) = 136.65 psi
fv* = = 47.66 psi
 fv* = 47.66 psi < Fvx' = 136.65 psi  (CSI = 0.35)   ➜  OK
fv = = 52.83 psi
 fv = 52.83 psi < Fvx' = 136.65 psi  (CSI = 0.39)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1900000(0.9)(0.9)(1) = 1539000 psi
10/5/2021 5
ΔLL = = 0.30 in.
(L/d)LL = 189.00 / 0.30 = 624
 ΔLL = 0.30 in = L/624 < L/360   ➜  OK
ΔTL = = 0.56 in.
(L/d)TL = 189.00 / 0.56 = 335
 ΔTL = 0.56 in = L/335 < L/240   ➜  OK
Fc⊥x' = (660)(0.67)(0.7)(1) = 309.54 psi
fc⊥ = = 110.3 psi
 fc⊥ = 110.3 psi < Fc⊥x' = 309.54 psi  (CSI = 0.36)   ➜  OK
10/5/2021 6
