Size: 5.5 x 12
Design Span (L): 26.25 ft.
Clear Span: 26.00 ft.
Total Span: 26.50 ft.
Selfweight: 406.2 lbs
Dist. Selfweight: 15.47 plf
Total Weight: 410.1 lbs
CV Volume Factor 0.971b - - - - -
Beam Design 2021A577
10/5/2021 1
10/5/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [66.00 x (315.00 + 3)] x (12 in./ft.)3 = 12.15 ft3
Volumespan = N[A x L] = 1 x [66.00 x 315.00] x (12 in./ft.)3 = 12.03 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 12.15 = 410.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 12.03 = 406.2 lbs
  ws = 15.47 plf
26.25 ft.
26.00 ft.
26.50 ft.
2523.78 lbs
2523.78 lbs
10/5/2021 3
CV = = 0.971
CV = 0.971 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.971) = 2680.1 psi
fb = = 1491.5 psi
 fb = 1491.5 psi < Fbx' = 2680.1 psi  (CSI = 0.56)   ➜  OK
10/5/2021 4
fv* = = 52.49 psi
 fv* = 52.49 psi < Fvx' = 304.75 psi  (CSI = 0.17)   ➜  OK
fv = = 56.82 psi
 fv = 56.82 psi < Fvx' = 304.75 psi  (CSI = 0.19)   ➜  OK
10/5/2021 5
ΔLL = = 0.75 in.
(L/d)LL = 315.00 / 0.75 = 420
 ΔLL = 0.75 in = L/420 < L/180   ➜  OK
ΔTL = = 1.43 in.
(L/d)TL = 315.00 / 1.43 = 221
 ΔTL = 1.43 in = L/221 < L/120   ➜  OK
fc⊥ = = 153.0 psi
 fc⊥ = 153.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.24)   ➜  OK
10/5/2021 6
