Size: 5.125 x 10.5
Design Span (L): 13.25 ft.
Clear Span: 13.00 ft.
Total Span: 13.50 ft.
Live Load: 390 plf
Dead Load: 370 plf
Selfweight: 167.2 lbs
Dist. Selfweight: 12.62 plf
Total Weight: 170.3 lbs
Beam Design 2021A575
10/5/2021 1
b = 5.125 in.
d = 10.500 in.
A = 5.125 x 10.500 = 53.81 in.2
Sx = (5.125)(10.500)2/6 = 94.17 in.3
Sy = (5.125)2(10.500)/6 = 45.96 in.3
Ix = (5.125)(10.500)3/12 = 494.40 in.4
Iy = (5.125)3(10.500)/12 = 117.78 in.4
10/5/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [53.81 x (159.00 + 3)] x (12 in./ft.)3 = 5.04 ft3
Volumespan = N[A x L] = 1 x [53.81 x 159.00] x (12 in./ft.)3 = 4.95 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.04 = 170.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 4.95 = 167.2 lbs
Distributed Self Weight (ws) = = 12.62 plf
390 plf
370 plf
  ws = 12.62 plf
13.25 ft.
13.00 ft.
13.50 ft.
5215.16 lbs
5215.16 lbs
10/5/2021 3
fb = = 2160.6 psi
 fb = 2160.6 psi < Fbx' = 2400.0 psi  (CSI = 0.90)   ➜  OK
10/5/2021 4
fv* = = 123.83 psi
 fv* = 123.83 psi < Fvx' = 265.00 psi  (CSI = 0.47)   ➜  OK
fv = = 142.68 psi
 fv = 142.68 psi < Fvx' = 265.00 psi  (CSI = 0.54)   ➜  OK
10/5/2021 5
ΔLL = = 0.30 in.
(L/d)LL = 159.00 / 0.30 = 523
 ΔLL = 0.30 in = L/523 < L/360   ➜  OK
ΔTL = = 0.60 in.
(L/d)TL = 159.00 / 0.60 = 264
 ΔTL = 0.60 in = L/264 < L/240   ➜  OK
fc⊥ = = 339.2 psi
 fc⊥ = 339.2 psi < Fc⊥x' = 650.00 psi  (CSI = 0.52)   ➜  OK
10/5/2021 6
