Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 308 plf
Dead Load: 70 plf
Selfweight: 55.8 lbs
Dist. Selfweight: 7.19 plf
Total Weight: 57.6 lbs
Beam Design IRON MUSTANGS 2021A573
10/4/2021 1
10/4/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (93.00 + 3)] x (12 in./ft.)3 = 1.54 ft3
Volumespan = N[A x L] = 2 x [13.88 x 93.00] x (12 in./ft.)3 = 1.49 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.54 = 57.6 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.49 = 55.8 lbs
308 plf
70 plf
ws = 7.19 plf
7.75 ft.
7.50 ft.
1540.78 lbs
1540.78 lbs
10/4/2021 3
fb = = 811.2 psi
 fb = 811.2 psi < Fbx' = 920.0 psi  (CSI = 0.88)   ➜  OK
10/4/2021 4
fv* = = 64.63 psi
 fv* = 64.63 psi < Fvx' = 201.25 psi  (CSI = 0.32)   ➜  OK
fv = = 80.68 psi
 fv = 80.68 psi < Fvx' = 201.25 psi  (CSI = 0.40)   ➜  OK
10/4/2021 5
ΔLL = = 0.09 in.
(L/d)LL = 93.00 / 0.09 = 1030
 ΔLL = 0.09 in = L/1030 < L/360   ➜  OK
ΔTL = = 0.11 in.
(L/d)TL = 93.00 / 0.11 = 824
 ΔTL = 0.11 in = L/824 < L/240   ➜  OK
fc⊥ = = 171.2 psi
 fc⊥ = 171.2 psi < Fc⊥x' = 565.00 psi  (CSI = 0.30)   ➜  OK
10/4/2021 6
