Beam Design - kitchen beam
Size: 3.5 x 12
Design Span (L): 14.25 ft.
Clear Span: 14.00 ft.
Total Span: 14.50 ft.
Selfweight: 140.3 lbs
Dist. Selfweight: 9.85 plf
Total Weight: 142.8 lbs
Beam Design Mark Solomon 722 S. Jefferson Woodland
10/2/2021 1
10/2/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [42.00 x (171.00 + 3)] x (12 in./ft.)3 = 4.23 ft3
Volumespan = N[A x L] = 1 x [42.00 x 171.00] x (12 in./ft.)3 = 4.16 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 4.23 = 142.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 4.16 = 140.3 lbs
  ws = 9.85 plf
14.25 ft.
14.50 ft.
1340.14 lbs
1340.14 lbs
10/2/2021 3
fb = = 670.3 psi
 fb = 670.3 psi < Fbx' = 2400.0 psi  (CSI = 0.28)   ➜  OK
10/2/2021 4
fv* = = 40.44 psi
 fv* = 40.44 psi < Fvx' = 265.00 psi  (CSI = 0.15)   ➜  OK
fv = = 47.04 psi
 fv = 47.04 psi < Fvx' = 265.00 psi  (CSI = 0.18)   ➜  OK
10/2/2021 5
ΔLL = = 0.10 in.
(L/d)LL = 171.00 / 0.10 = 1672
 ΔLL = 0.10 in = L/1672 < L/360   ➜  OK
ΔTL = = 0.19 in.
(L/d)TL = 171.00 / 0.19 = 905
 ΔTL = 0.19 in = L/905 < L/240   ➜  OK
fc⊥ = = 127.6 psi
 fc⊥ = 127.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.20)   ➜  OK
10/2/2021 6
