Size: 5.5 x 10.5
Design Span (L): 19.08 ft.
Clear Span: 18.83 ft.
Total Span: 19.33 ft.
Live Load: 133 plf
Dead Load: 50 plf
Selfweight: 258.3 lbs
Dist. Selfweight: 13.54 plf
Total Weight: 261.7 lbs
CL Beam Stability Factor 0.972 - - - - -
Beam Design 2021A57
1/16/2021 1
d = 10.500 in.
A = 5.500 x 10.500 = 57.75 in.2
Sx = (5.500)(10.500)2/6 = 101.06 in.3
Sy = (5.500)2(10.500)/6 = 52.94 in.3
Ix = (5.500)(10.500)3/12 = 530.58 in.4
Iy = (5.500)3(10.500)/12 = 145.58 in.4
Beam Design 2021A57
1/16/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [57.75 x (228.96 + 3)] x (12 in./ft.)3 = 7.75 ft3
Volumespan = N[A x L] = 1 x [57.75 x 228.96] x (12 in./ft.)3 = 7.65 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.75 = 261.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.65 = 258.3 lbs
133 plf
50 plf
  ws = 13.54 plf
19.08 ft.
18.83 ft.
19.33 ft.
1899.56 lbs
1899.56 lbs
Beam Design 2021A57
1/16/2021 3
lu = Unbraced Length = 19.080 ft.
lu/d = = 21.81
le = 1.63lu + 3d = 1.63(229.0) + 3(10.5) = 404.70 in. = 33.73 ft.  (NDS Table 3.3.3)
Rb = = 11.85
 Rb = 11.85 < 50   ➜  OK
Beam Design 2021A57
1/16/2021 4
FbE = = 7261.02 psi
CL =   = 0.972
CL = 0.972 < CV = 1.0
Fbx' = (2400)(1.15)(1)(1)(0.972) = 2681.5 psi
fb = = 1062.0 psi
 fb = 1062.0 psi < Fbx' = 2681.5 psi  (CSI = 0.40)   ➜  OK
fv* = = 44.23 psi
Beam Design 2021A57
1/16/2021 5
 fv* = 44.23 psi < Fvx' = 304.75 psi  (CSI = 0.15)   ➜  OK
fv = = 48.70 psi
 fv = 48.70 psi < Fvx' = 304.75 psi  (CSI = 0.16)   ➜  OK
ΔLL = = 0.42 in.
(L/d)LL = 228.96 / 0.42 = 551
 ΔLL = 0.42 in = L/551 < L/360   ➜  OK
ΔTL = = 0.61 in.
(L/d)TL = 228.96 / 0.61 = 373
 ΔTL = 0.61 in = L/373 < L/240   ➜  OK
Beam Design 2021A57
1/16/2021 6
fc⊥ = = 115.1 psi
 fc⊥ = 115.1 psi < Fc⊥x' = 650.00 psi  (CSI = 0.18)   ➜  OK
Beam Design 2021A57
1/16/2021 7
