Design Span (L): 10.13 ft.
Clear Span: 9.67 ft.
Total Span: 10.58 ft.
Bearing (lb): 5.5 in.
Live Load: 315 plf
Dead Load: 153 plf
Selfweight: 88.6 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 92.6 lbs
Beam Design 2021A569
10/1/2021 1
10/1/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (121.50 + 5.5)] x (12 in./ft.)3 = 2.48 ft3
Volumespan = N[A x L] = 2 x [16.88 x 121.50] x (12 in./ft.)3 = 2.37 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 2.48 = 92.6 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 2.37 = 88.6 lbs
315 plf
153 plf
ws = 8.75 plf
10.13 ft.
9.67 ft.
10.58 ft.
2522.80 lbs
2522.80 lbs
10/1/2021 3
Fbx' = (750)(1.00)(1)(1)(1)(1)(1)(1) = 750.0 psi
fb = = 1158.5 psi
 fb = 1158.5 psi > Fbx' = 750.0 psi  (CSI = 1.54)   ➜  NG
10/1/2021 4
fv* = = 87.40 psi
 fv* = 87.40 psi < Fvx' = 175.00 psi  (CSI = 0.50)   ➜  OK
fv = = 107.27 psi
 fv = 107.27 psi < Fvx' = 175.00 psi  (CSI = 0.61)   ➜  OK
10/1/2021 5
ΔLL = = 0.15 in.
(L/d)LL = 121.50 / 0.15 = 813
 ΔLL = 0.15 in = L/813 < L/360   ➜  OK
ΔTL = = 0.23 in.
(L/d)TL = 121.50 / 0.23 = 537
 ΔTL = 0.23 in = L/537 < L/240   ➜  OK
fc⊥ = = 152.9 psi
 fc⊥ = 152.9 psi < Fc⊥x' = 565.00 psi  (CSI = 0.27)   ➜  OK
10/1/2021 6
