Design Span (L): 8.35 ft.
Clear Span: 8.10 ft.
Total Span: 8.60 ft.
Live Load: 200 plf
Selfweight: 43.1 lbs
Dist. Selfweight: 5.17 plf
Total Weight: 44.4 lbs
Beam Design 2021A568
10/1/2021 1
10/1/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (100.20 + 3)] x (12 in./ft.)3 = 1.30 ft3
Volumespan = N[A x L] = 2 x [10.88 x 100.20] x (12 in./ft.)3 = 1.26 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.30 = 44.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.26 = 43.1 lbs
200 plf
ws = 5.17 plf
8.35 ft.
8.10 ft.
8.60 ft.
1204.71 lbs
1204.71 lbs
10/1/2021 3
fb = = 1114.9 psi
 fb = 1114.9 psi < Fbx' = 1242.0 psi  (CSI = 0.90)   ➜  OK
10/1/2021 4
fv* = = 68.99 psi
 fv* = 68.99 psi < Fvx' = 207.00 psi  (CSI = 0.33)   ➜  OK
fv = = 80.67 psi
 fv = 80.67 psi < Fvx' = 207.00 psi  (CSI = 0.39)   ➜  OK
10/1/2021 5
ΔLL = = 0.14 in.
(L/d)LL = 100.20 / 0.14 = 698
 ΔLL = 0.14 in = L/698 < L/180   ➜  OK
ΔTL = = 0.20 in.
(L/d)TL = 100.20 / 0.20 = 498
 ΔTL = 0.20 in = L/498 < L/120   ➜  OK
fc⊥ = = 133.9 psi
 fc⊥ = 133.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.21)   ➜  OK
10/1/2021 6
