Beam Design - MR
Design Span (L): 13.25 ft.
Clear Span: 13.00 ft.
Total Span: 13.50 ft.
Live Load: 787.5 plf
Dead Load: 258.75 plf
Selfweight: 115.9 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 118.1 lbs
Beam Design CARLOS REYES 54 FOREST PL ROCHELLE PK. NJ 2.000.00
10/1/2021 1
10/1/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (159.00 + 3)] x (12 in./ft.)3 = 3.16 ft3
Volumespan = N[A x L] = 2 x [16.88 x 159.00] x (12 in./ft.)3 = 3.11 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 3.16 = 118.1 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 3.11 = 115.9 lbs
787.5 plf
258.75 plf
ws = 8.75 plf
13.25 ft.
13.00 ft.
13.50 ft.
7121.24 lbs
7121.24 lbs
10/1/2021 3
fb = = 4390.4 psi
 fb = 4390.4 psi > Fbx' = 862.5 psi  (CSI = 5.09)   ➜  NG
10/1/2021 4
fv* = = 266.68 psi
 fv* = 266.68 psi > Fvx' = 201.25 psi  (CSI = 1.33)   ➜  NG
fv = = 310.64 psi
 fv = 310.64 psi > Fvx' = 201.25 psi  (CSI = 1.54)   ➜  NG
10/1/2021 5
ΔLL = = 1.10 in.
(L/d)LL = 159.00 / 1.10 = 145
 ΔLL = 1.10 in = L/145 > L/360   ➜  NG
ΔTL = = 1.47 in.
(L/d)TL = 159.00 / 1.47 = 108
 ΔTL = 1.47 in = L/108 > L/240   ➜  NG
fc⊥ = = 791.2 psi
 fc⊥ = 791.2 psi > Fc⊥x' = 565.00 psi  (CSI = 1.40)   ➜  NG
10/1/2021 6
