Beam Design - MR
Grade: SP DSS
Design Span (L): 13.25 ft.
Clear Span: 13.00 ft.
Total Span: 13.50 ft.
Live Load: 450 plf
Dead Load: 146.25 plf
Selfweight: 115.9 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 118.1 lbs
Beam Design CARLOS REYES 54 FOREST PL ROCHELLE PK. NJ 2.000.00
10/1/2021 1
10/1/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (159.00 + 3)] x (12 in./ft.)3 = 3.16 ft3
Volumespan = N[A x L] = 2 x [16.88 x 159.00] x (12 in./ft.)3 = 3.11 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 3.16 = 118.1 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 3.11 = 115.9 lbs
450 plf
146.25 plf
ws = 8.75 plf
13.25 ft.
13.00 ft.
13.50 ft.
4083.74 lbs
4083.74 lbs
10/1/2021 3
fb = = 2517.7 psi
 fb = 2517.7 psi > Fbx' = 2070.0 psi  (CSI = 1.22)   ➜  NG
10/1/2021 4
fv* = = 152.93 psi
 fv* = 152.93 psi < Fvx' = 201.25 psi  (CSI = 0.76)   ➜  OK
fv = = 178.14 psi
 fv = 178.14 psi < Fvx' = 201.25 psi  (CSI = 0.89)   ➜  OK
10/1/2021 5
ΔLL = = 0.46 in.
(L/d)LL = 159.00 / 0.46 = 345
 ΔLL = 0.46 in = L/345 > L/360   ➜  NG
ΔTL = = 0.62 in.
(L/d)TL = 159.00 / 0.62 = 256
 ΔTL = 0.62 in = L/256 < L/240   ➜  OK
fc⊥ = = 453.7 psi
 fc⊥ = 453.7 psi < Fc⊥x' = 660.00 psi  (CSI = 0.69)   ➜  OK
10/1/2021 6
