Species: Hem-Fir
Grade: HF No.2
Design Span (L): 11.00 ft.
Clear Span: 10.50 ft.
Total Span: 11.50 ft.
Quantity (N): 4
Live Load: 330 plf
Dead Load: 220 plf
Selfweight: 153.4 lbs
Dist. Selfweight: 13.94 plf
Total Weight: 160.3 lbs
Beam Design 61 Elm Street, Somerville, MA 2021A562
9/30/2021 1
G = 0.43
9/30/2021 2
= 29.74 lbs/ft3
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (132.00 + 6)] x (12 in./ft.)3 = 5.39 ft3
Volumespan = N[A x L] = 4 x [16.88 x 132.00] x (12 in./ft.)3 = 5.16 ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 5.39 = 160.3 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 5.16 = 153.4 lbs
Distributed Self Weight (ws) = = 13.94 plf
330 plf
220 plf
ws = 13.94 plf
11.00 ft.
10.50 ft.
3242.67 lbs
3242.67 lbs
9/30/2021 3
lu = Unbraced Length = 11.000 ft.
lu/d = = 11.73
le = 1.63lu + 3d = 1.63(132.0) + 3(11.25) = 248.91 in. = 20.74 ft.  (NDS Table 3.3.3)
Rb = = 8.82
 Rb = 8.82 < 50   ➜  OK
9/30/2021 4
Eminy' = Eminy(CM)(Ct)(Ci) = 470000(1)(1)(1) = 470000 psi
FbE = = 7250.81 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (850)(1.00)(1)(1)(1)(1)(1) = 850.00 psi
CL =   = 0.993
Fbx' = (850)(1.00)(1)(1)(0.993)(1)(1)(1) = 844.4 psi
fb = = 808.7 psi
 fb = 808.7 psi < Fbx' = 844.4 psi  (CSI = 0.96)   ➜  OK
Fvx' = (150)(1.00)(1)(1)(1) = 150.00 psi
fv* = = 57.18 psi
 fv* = 57.18 psi < Fvx' = 150.00 psi  (CSI = 0.38)   ➜  OK
fv = = 68.93 psi
 fv = 68.93 psi < Fvx' = 150.00 psi  (CSI = 0.46)   ➜  OK
9/30/2021 5
ΔLL = = 0.12 in.
(L/d)LL = 132.00 / 0.12 = 1124
 ΔLL = 0.12 in = L/1124 < L/360   ➜  OK
ΔTL = = 0.20 in.
(L/d)TL = 132.00 / 0.20 = 658
 ΔTL = 0.20 in = L/658 < L/240   ➜  OK
fc⊥ = = 90.1 psi
 fc⊥ = 90.1 psi < Fc⊥x' = 405.00 psi  (CSI = 0.22)   ➜  OK
9/30/2021 6
