Size: 5.5 x 9
Design Span (L): 19.33 ft.
Clear Span: 18.83 ft.
Total Span: 19.83 ft.
Live Load: 133 plf
Dead Load: 50 plf
Selfweight: 224.3 lbs
Dist. Selfweight: 11.61 plf
Total Weight: 230.1 lbs
Beam Design BLIGHT
1/16/2021 1
d = 9.000 in.
Beam Design BLIGHT
1/16/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [49.50 x (231.96 + 6)] x (12 in./ft.)3 = 6.82 ft3
Volumespan = N[A x L] = 1 x [49.50 x 231.96] x (12 in./ft.)3 = 6.64 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 6.82 = 230.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 6.64 = 224.3 lbs
Distributed Self Weight (ws) = = 11.61 plf
133 plf
50 plf
  ws = 11.61 plf
19.33 ft.
18.83 ft.
19.83 ft.
1929.51 lbs
1929.51 lbs
Beam Design BLIGHT
1/16/2021 3
fb = = 1469.0 psi
 fb = 1469.0 psi < Fbx' = 2760.0 psi  (CSI = 0.53)   ➜  OK
Beam Design BLIGHT
1/16/2021 4
fv* = = 52.57 psi
 fv* = 52.57 psi < Fvx' = 304.75 psi  (CSI = 0.17)   ➜  OK
fv = = 57.00 psi
 fv = 57.00 psi < Fvx' = 304.75 psi  (CSI = 0.19)   ➜  OK
Beam Design BLIGHT
1/16/2021 5
ΔLL = = 0.69 in.
(L/d)LL = 231.96 / 0.69 = 334
 ΔLL = 0.69 in = L/334 > L/360   ➜  NG
ΔTL = = 1.02 in.
(L/d)TL = 231.96 / 1.02 = 228
 ΔTL = 1.02 in = L/228 > L/240   ➜  NG
fc⊥ = = 58.5 psi
 fc⊥ = 58.5 psi < Fc⊥x' = 650.00 psi  (CSI = 0.09)   ➜  OK
Beam Design BLIGHT
1/16/2021 6
