Size: 3.5 x 15
Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 480 plf
Dead Load: 120 plf
Selfweight: 169.2 lbs
Dist. Selfweight: 12.31 plf
Total Weight: 172.3 lbs
Beam Design 2021A557
9/28/2021 1
d = 15.000 in.
9/28/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (165.00 + 3)] x (12 in./ft.)3 = 5.10 ft3
Volumespan = N[A x L] = 1 x [52.50 x 165.00] x (12 in./ft.)3 = 5.01 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.10 = 172.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.01 = 169.2 lbs
480 plf
120 plf
  ws = 12.31 plf
13.75 ft.
13.50 ft.
4286.16 lbs
4286.16 lbs
9/28/2021 3
fb = = 1323.0 psi
 fb = 1323.0 psi < Fbx' = 2400.0 psi  (CSI = 0.55)   ➜  OK
9/28/2021 4
fv* = = 98.41 psi
 fv* = 98.41 psi < Fvx' = 265.00 psi  (CSI = 0.37)   ➜  OK
fv = = 120.27 psi
 fv = 120.27 psi < Fvx' = 265.00 psi  (CSI = 0.45)   ➜  OK
9/28/2021 5
ΔLL = = 0.22 in.
(L/d)LL = 165.00 / 0.22 = 757
 ΔLL = 0.22 in = L/757 < L/360   ➜  OK
ΔTL = = 0.28 in.
(L/d)TL = 165.00 / 0.28 = 594
 ΔTL = 0.28 in = L/594 < L/240   ➜  OK
fc⊥ = = 408.2 psi
 fc⊥ = 408.2 psi < Fc⊥x' = 650.00 psi  (CSI = 0.63)   ➜  OK
9/28/2021 6
