Size: 5.125 x 12
Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 480 plf
Dead Load: 120 plf
Selfweight: 198.3 lbs
Dist. Selfweight: 14.42 plf
Total Weight: 201.9 lbs
Beam Design 2021A555
9/28/2021 1
b = 5.125 in.
9/28/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [61.50 x (165.00 + 3)] x (12 in./ft.)3 = 5.98 ft3
Volumespan = N[A x L] = 1 x [61.50 x 165.00] x (12 in./ft.)3 = 5.87 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.98 = 201.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.87 = 198.3 lbs
480 plf
120 plf
  ws = 14.42 plf
13.75 ft.
13.50 ft.
4300.93 lbs
4300.93 lbs
9/28/2021 3
fb = = 1416.6 psi
 fb = 1416.6 psi < Fbx' = 2400.0 psi  (CSI = 0.59)   ➜  OK
9/28/2021 4
fv* = = 88.04 psi
 fv* = 88.04 psi < Fvx' = 265.00 psi  (CSI = 0.33)   ➜  OK
fv = = 103.03 psi
 fv = 103.03 psi < Fvx' = 265.00 psi  (CSI = 0.39)   ➜  OK
9/28/2021 5
ΔLL = = 0.29 in.
(L/d)LL = 165.00 / 0.29 = 568
 ΔLL = 0.29 in = L/568 < L/360   ➜  OK
ΔTL = = 0.37 in.
(L/d)TL = 165.00 / 0.37 = 444
 ΔTL = 0.37 in = L/444 < L/240   ➜  OK
fc⊥ = = 279.7 psi
 fc⊥ = 279.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.43)   ➜  OK
9/28/2021 6
