Beam Design - BEAM DESIGN
Size: 6.75 x 18
Design Span (L): 24.75 ft.
Clear Span: 24.50 ft.
Total Span: 25.00 ft.
Live Load: 1190 lbs
Dead Load: 2500 lbs
Selfweight: 705.0 lbs
Dist. Selfweight: 28.49 plf
Total Weight: 712.2 lbs
CV Volume Factor 0.919b - - - - -
Beam Design Milfrise Livens AV.LOS RIOS ED. PUXCATAN DEP. C 401 1
9/28/2021 1
b = 6.750 in.
d = 18.000 in.
A = 6.750 x 18.000 = 121.50 in.2
Sx = (6.750)(18.000)2/6 = 364.50 in.3
Sy = (6.750)2(18.000)/6 = 136.69 in.3
Ix = (6.750)(18.000)3/12 = 3280.50 in.4
Iy = (6.750)3(18.000)/12 = 461.32 in.4
9/28/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [121.50 x (297.00 + 3)] x (12 in./ft.)3 = 21.09 ft3
Volumespan = N[A x L] = 1 x [121.50 x 297.00] x (12 in./ft.)3 = 20.88 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 21.09 = 712.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 20.88 = 705.0 lbs
Distributed Self Weight (ws) = = 28.49 plf
1190 lbs
2500 lbs
  ws = 28.49 plf
24.75 ft.
24.50 ft.
25.00 ft.
2201.08 lbs
2201.08 lbs
9/28/2021 3
CV = = 0.919
CV = 0.919 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.919) = 2536.3 psi
fb = = 823.5 psi
 fb = 823.5 psi < Fbx' = 2536.3 psi  (CSI = 0.32)   ➜  OK
9/28/2021 4
fv* = = 26.60 psi
 fv* = 26.60 psi < Fvx' = 304.75 psi  (CSI = 0.09)   ➜  OK
fv = = 27.13 psi
 fv = 27.13 psi < Fvx' = 304.75 psi  (CSI = 0.09)   ➜  OK
9/28/2021 5
ΔLL =   =   = 0.11 in.
(L/d)LL = 297.00 / 0.11 = 2700
 ΔLL = 0.11 in = L/2700 < L/360   ➜  OK
ΔTL =   =   = 0.38 in.
(L/d)TL = 297.00 / 0.38 = 778
 ΔTL = 0.38 in = L/778 < L/240   ➜  OK
fc⊥ = = 108.7 psi
 fc⊥ = 108.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.17)   ➜  OK
9/28/2021 6
