Grade: SPF No.2
Design Span (L): 9.30 ft.
Clear Span: 9.18 ft.
Total Span: 9.43 ft.
Bearing (lb): 1.5 in.
Live Load: 40 plf
Dead Load: 23 plf
Selfweight: 15.5 lbs
Dist. Selfweight: 1.67 plf
Total Weight: 15.7 lbs
Beam Design 2021A552
9/26/2021 1
9/26/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (111.60 + 1.5)] x (12 in./ft.)3 = 0.54 ft3
Volumespan = N[A x L] = 1 x [8.25 x 111.60] x (12 in./ft.)3 = 0.53 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.54 = 15.7 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.53 = 15.5 lbs
40 plf
23 plf
ws = 1.67 plf
9.30 ft.
9.18 ft.
9.43 ft.
304.74 lbs
304.74 lbs
9/26/2021 3
Fbx' = (875)(1.00)(1)(1)(1)(1.3)(1)(1) = 1137.5 psi
fb = = 1109.4 psi
 fb = 1109.4 psi < Fbx' = 1137.5 psi  (CSI = 0.98)   ➜  OK
9/26/2021 4
fv* = = 49.28 psi
 fv* = 49.28 psi < Fvx' = 135.00 psi  (CSI = 0.37)   ➜  OK
fv = = 54.67 psi
 fv = 54.67 psi < Fvx' = 135.00 psi  (CSI = 0.40)   ➜  OK
9/26/2021 5
ΔLL = = 0.23 in.
(L/d)LL = 111.60 / 0.23 = 483
 ΔLL = 0.23 in = L/483 < L/360   ➜  OK
ΔTL = = 0.37 in.
(L/d)TL = 111.60 / 0.37 = 299
 ΔTL = 0.37 in = L/299 < L/240   ➜  OK
fc⊥ = = 135.4 psi
 fc⊥ = 135.4 psi < Fc⊥x' = 425.00 psi  (CSI = 0.32)   ➜  OK
9/26/2021 6
