Beam Design - New Platforms and New Roof Curbs for AC Units
Design Span (L): 6.92 ft.
Clear Span: 6.84 ft.
Total Span: 7.00 ft.
Bearing (lb): 1 in.
Live Load: 20 plf
Dead Load: 60 plf
Selfweight: 13.6 lbs
Dist. Selfweight: 1.96 plf
Total Weight: 13.7 lbs
Defl. Limits: 600|400
Beam Design Hamid Es 2021A551
9/24/2021 1
9/24/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (83.04 + 1)] x (12 in./ft.)3 = 0.40 ft3
Volumespan = N[A x L] = 1 x [8.25 x 83.04] x (12 in./ft.)3 = 0.40 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.40 = 13.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.40 = 13.6 lbs
20 plf
60 plf
ws = 1.96 plf
6.92 ft.
6.84 ft.
7.00 ft.
287.00 lbs
287.00 lbs
9/24/2021 3
fb = = 778.5 psi
 fb = 778.5 psi < Fbx' = 1170.0 psi  (CSI = 0.67)   ➜  OK
9/24/2021 4
fv* = = 44.73 psi
 fv* = 44.73 psi < Fvx' = 180.00 psi  (CSI = 0.25)   ➜  OK
fv = = 51.56 psi
 fv = 51.56 psi < Fvx' = 180.00 psi  (CSI = 0.29)   ➜  OK
LL Allowable: L/600
TL Allowable: L/400
9/24/2021 5
ΔLL = = 0.03 in.
(L/d)LL = 83.04 / 0.03 = 2678
 ΔLL = 0.03 in = L/2678 < L/600   ➜  OK
ΔTL = = 0.13 in.
(L/d)TL = 83.04 / 0.13 = 653
 ΔTL = 0.13 in = L/653 < L/400   ➜  OK
Ab = b x lb = 1.5 x 1 = 1.50 in2
fc⊥ = = 191.3 psi
 fc⊥ = 191.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.31)   ➜  OK
9/24/2021 6
