Design Span (L): 6.92 ft.
Clear Span: 6.83 ft.
Total Span: 7.00 ft.
Bearing (lb): 1 in.
Live Load: 20 plf
Dead Load: 60 plf
Selfweight: 13.6 lbs
Dist. Selfweight: 1.96 plf
Total Weight: 13.7 lbs
Defl. Limits: 480|360
Load Duration: 2.00
CD Load Duration Factor 2.00 2.00 2.00 2.00 - -
Beam Design 2021A548
9/24/2021 1
9/24/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (83.00 + 1)] x (12 in./ft.)3 = 0.40 ft3
Volumespan = N[A x L] = 1 x [8.25 x 83.00] x (12 in./ft.)3 = 0.40 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.40 = 13.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.40 = 13.6 lbs
20 plf
60 plf
ws = 1.96 plf
6.92 ft.
6.83 ft.
7.00 ft.
286.87 lbs
286.87 lbs
9/24/2021 3
Fbx' = (900)(2.00)(1)(1)(1)(1.3)(1)(1) = 2340.0 psi
fb = = 777.8 psi
 fb = 777.8 psi < Fbx' = 2340.0 psi  (CSI = 0.33)   ➜  OK
9/24/2021 4
Fvx' = (180)(2.00)(1)(1)(1) = 360.00 psi
fv* = = 44.71 psi
 fv* = 44.71 psi < Fvx' = 360.00 psi  (CSI = 0.12)   ➜  OK
fv = = 51.54 psi
 fv = 51.54 psi < Fvx' = 360.00 psi  (CSI = 0.14)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
9/24/2021 5
ΔLL = = 0.03 in.
(L/d)LL = 83.00 / 0.03 = 2681
 ΔLL = 0.03 in = L/2681 < L/480   ➜  OK
ΔTL = = 0.13 in.
(L/d)TL = 83.00 / 0.13 = 654
 ΔTL = 0.13 in = L/654 < L/360   ➜  OK
Ab = b x lb = 1.5 x 1 = 1.50 in2
fc⊥ = = 191.2 psi
 fc⊥ = 191.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.31)   ➜  OK
9/24/2021 6
