Grade: SP DSS
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 397.2 plf
Dead Load: 88.8 plf
Selfweight: 27.9 lbs
Dist. Selfweight: 3.60 plf
Total Weight: 28.8 lbs
Beam Design James Radke 310 N St Helen Rd 2021A544
9/21/2021 1
9/21/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (93.00 + 3)] x (12 in./ft.)3 = 0.77 ft3
Volumespan = N[A x L] = 1 x [13.88 x 93.00] x (12 in./ft.)3 = 0.75 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.77 = 28.8 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.75 = 27.9 lbs
397.2 plf
88.8 plf
ws = 3.60 plf
7.75 ft.
7.50 ft.
1958.39 lbs
1958.39 lbs
9/21/2021 3
Fbx' = (1950)(1.15)(1)(1)(1)(1)(1)(1) = 2242.5 psi
fb = = 2062.1 psi
 fb = 2062.1 psi < Fbx' = 2242.5 psi  (CSI = 0.92)   ➜  OK
9/21/2021 4
fv* = = 164.30 psi
 fv* = 164.30 psi < Fvx' = 201.25 psi  (CSI = 0.82)   ➜  OK
fv = = 205.10 psi
 fv = 205.10 psi > Fvx' = 201.25 psi  (CSI = 1.02)   ➜  NG
9/21/2021 5
ΔLL = = 0.17 in.
(L/d)LL = 93.00 / 0.17 = 542
 ΔLL = 0.17 in = L/542 < L/360   ➜  OK
ΔTL = = 0.21 in.
(L/d)TL = 93.00 / 0.21 = 440
 ΔTL = 0.21 in = L/440 < L/240   ➜  OK
fc⊥ = = 435.2 psi
 fc⊥ = 435.2 psi < Fc⊥x' = 660.00 psi  (CSI = 0.66)   ➜  OK
9/21/2021 6
