Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Live Load: 450 lbs
Dead Load: 0 lbs
Selfweight: 267.9 lbs
Dist. Selfweight: 13.56 plf
Total Weight: 271.3 lbs
Incised Lumber: Yes
CL Beam Stability Factor 0.986 - - - - -
Beam Design 2021A543
9/17/2021 1
9/17/2021 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (237.00 + 3)] x (12 in./ft.)3 = 7.03 ft3
Volumespan = N[A x L] = 3 x [16.88 x 237.00] x (12 in./ft.)3 = 6.94 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 7.03 = 271.3 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 6.94 = 267.9 lbs
Distributed Self Weight (ws) = = 13.56 plf
450 lbs
0 lbs
ws = 13.56 plf
19.75 ft.
19.50 ft.
360.64 lbs
360.64 lbs
9/17/2021 3
lu = Unbraced Length = 19.750 ft.
lu/d = = 21.07
le = 1.37lu + 3d = 1.37(237.0) + 3(11.25) = 358.44 in. = 29.87 ft.  (NDS Table 3.3.3)
Rb = = 14.11
 Rb = 14.11 < 50   ➜  OK
9/17/2021 4
Eminy' = Eminy(CM)(Ct)(Ci) = 510000(0.9)(1)(0.95) = 436050 psi
FbE = = 2627.69 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (750)(1.00)(1)(1)(1)(0.8)(1) = 600.00 psi
CL =   = 0.986
Fbx' = (750)(1.00)(1)(1)(0.986)(1)(0.8)(1) = 591.4 psi
fb = = 364.5 psi
 fb = 364.5 psi < Fbx' = 591.4 psi  (CSI = 0.62)   ➜  OK
Fvx' = (175)(1.00)(0.97)(1)(0.8) = 135.80 psi
fv* = = 10.26 psi
 fv* = 10.26 psi < Fvx' = 135.80 psi  (CSI = 0.08)   ➜  OK
fv = = 10.64 psi
 fv = 10.64 psi < Fvx' = 135.80 psi  (CSI = 0.08)   ➜  OK
9/17/2021 5
Ex' = Ex(CM)(Ct)(Ci) = 1400000(0.9)(1)(0.95) = 1197000 psi
ΔLL =   =   = 0.20 in.
(L/d)LL = 237.00 / 0.20 = 1214
 ΔLL = 0.20 in = L/1214 < L/360   ➜  OK
ΔTL =   =   = 0.27 in.
(L/d)TL = 237.00 / 0.27 = 885
 ΔTL = 0.27 in = L/885 < L/240   ➜  OK
fc⊥ = = 26.7 psi
 fc⊥ = 26.7 psi < Fc⊥x' = 378.55 psi  (CSI = 0.07)   ➜  OK
9/17/2021 6
