Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 277.2 plf
Dead Load: 85.2 plf
Selfweight: 55.8 lbs
Dist. Selfweight: 7.19 plf
Total Weight: 57.6 lbs
Beam Design Matt Boyd 9077 Michigan 2021A542
9/16/2021 1
9/16/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (93.00 + 3)] x (12 in./ft.)3 = 1.54 ft3
Volumespan = N[A x L] = 2 x [13.88 x 93.00] x (12 in./ft.)3 = 1.49 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.54 = 57.6 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.49 = 55.8 lbs
277.2 plf
85.2 plf
ws = 7.19 plf
7.75 ft.
7.50 ft.
1478.38 lbs
1478.38 lbs
9/16/2021 3
fb = = 778.3 psi
 fb = 778.3 psi < Fbx' = 920.0 psi  (CSI = 0.85)   ➜  OK
9/16/2021 4
fv* = = 62.02 psi
 fv* = 62.02 psi < Fvx' = 201.25 psi  (CSI = 0.31)   ➜  OK
fv = = 77.41 psi
 fv = 77.41 psi < Fvx' = 201.25 psi  (CSI = 0.38)   ➜  OK
9/16/2021 5
ΔLL = = 0.08 in.
(L/d)LL = 93.00 / 0.08 = 1145
 ΔLL = 0.08 in = L/1145 < L/360   ➜  OK
ΔTL = = 0.11 in.
(L/d)TL = 93.00 / 0.11 = 859
 ΔTL = 0.11 in = L/859 < L/240   ➜  OK
fc⊥ = = 164.3 psi
 fc⊥ = 164.3 psi < Fc⊥x' = 565.00 psi  (CSI = 0.29)   ➜  OK
9/16/2021 6
