Beam Design - 6282 CLEARBROOK
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 567.2 plf
Dead Load: 126.8 plf
Selfweight: 62.1 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 64.1 lbs
Notes: THIS CALC IS FOR THE SPAN BETWEEN POSTS ON LOAD SIDES OF ROOF
Beam Design JOHNNY GREEN 6282 CLEARBROOK 2021A537
9/13/2021 1
9/13/2021 2
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.88 = 64.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.82 = 62.1 lbs
567.2 plf
126.8 plf
ws = 8.02 plf
7.75 ft.
7.50 ft.
2808.07 lbs
2808.07 lbs
9/13/2021 3
fb = = 999.5 psi
 fb = 999.5 psi < Fbx' = 1035.0 psi  (CSI = 0.97)   ➜  OK
9/13/2021 4
fv* = = 91.65 psi
 fv* = 91.65 psi < Fvx' = 207.00 psi  (CSI = 0.44)   ➜  OK
fv = = 120.90 psi
 fv = 120.90 psi < Fvx' = 207.00 psi  (CSI = 0.58)   ➜  OK
9/13/2021 5
ΔLL = = 0.08 in.
(L/d)LL = 93.00 / 0.08 = 1150
 ΔLL = 0.08 in = L/1150 < L/180   ➜  OK
ΔTL = = 0.10 in.
(L/d)TL = 93.00 / 0.10 = 930
 ΔTL = 0.10 in = L/930 < L/120   ➜  OK
fc⊥ = = 312.0 psi
 fc⊥ = 312.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.50)   ➜  OK
9/13/2021 6
