Beam Design - Porch Floor Beam
Species: Hem-Fir
Grade: HF No.2
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 256 plf
Dead Load: 40 plf
Selfweight: 36.3 lbs
Dist. Selfweight: 4.68 plf
Total Weight: 37.4 lbs
Beam Design Brent Jensen 2234 Sitgreaves 2021A533
9/12/2021 1
G = 0.43
9/12/2021 2
= 30.99 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (93.00 + 3)] x (12 in./ft.)3 = 1.21 ft3
Volumespan = N[A x L] = 2 x [10.88 x 93.00] x (12 in./ft.)3 = 1.17 ft3
Total Weight (WT) = ρw x Volumetotal = 30.99 x 1.21 = 37.4 lbs
Self Weight (WS) = ρw x Volumespan = 30.99 x 1.17 = 36.3 lbs
Distributed Self Weight (ws) = = 4.68 plf
256 plf
40 plf
ws = 4.68 plf
7.75 ft.
7.50 ft.
1202.72 lbs
1202.72 lbs
9/12/2021 3
Fbx' = (850)(1.15)(1)(1)(1)(1.2)(1)(1) = 1173.0 psi
fb = = 1030.8 psi
 fb = 1030.8 psi < Fbx' = 1173.0 psi  (CSI = 0.88)   ➜  OK
9/12/2021 4
fv* = = 67.83 psi
 fv* = 67.83 psi < Fvx' = 167.32 psi  (CSI = 0.41)   ➜  OK
fv = = 80.35 psi
 fv = 80.35 psi < Fvx' = 167.32 psi  (CSI = 0.48)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1300000(0.9)(1)(1) = 1170000 psi
9/12/2021 5
ΔLL = = 0.19 in.
(L/d)LL = 93.00 / 0.19 = 499
 ΔLL = 0.19 in = L/499 < L/360   ➜  OK
ΔTL = = 0.22 in.
(L/d)TL = 93.00 / 0.22 = 425
 ΔTL = 0.22 in = L/425 < L/240   ➜  OK
fc⊥ = = 133.6 psi
 fc⊥ = 133.6 psi < Fc⊥x' = 271.35 psi  (CSI = 0.49)   ➜  OK
9/12/2021 6
