Beam Design - Floor Beam
Size: 5.5 x 9
Design Span (L): 10.08 ft.
Clear Span: 9.83 ft.
Total Span: 10.33 ft.
Live Load: 640 plf
Dead Load: 160 plf
Selfweight: 117.0 lbs
Dist. Selfweight: 11.61 plf
Total Weight: 119.9 lbs
Defl. Limits: 480|360
Beam Design Brent Jensen 2234 Sitgreaves
9/12/2021 1
d = 9.000 in.
9/12/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [49.50 x (120.96 + 3)] x (12 in./ft.)3 = 3.55 ft3
Volumespan = N[A x L] = 1 x [49.50 x 120.96] x (12 in./ft.)3 = 3.46 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.55 = 119.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.46 = 117.0 lbs
Distributed Self Weight (ws) = = 11.61 plf
640 plf
160 plf
  ws = 11.61 plf
10.08 ft.
9.83 ft.
10.33 ft.
4191.94 lbs
4191.94 lbs
9/12/2021 3
fb = = 1665.9 psi
 fb = 1665.9 psi < Fbx' = 2400.0 psi  (CSI = 0.69)   ➜  OK
9/12/2021 4
fv* = = 105.51 psi
 fv* = 105.51 psi < Fvx' = 265.00 psi  (CSI = 0.40)   ➜  OK
fv = = 123.95 psi
 fv = 123.95 psi < Fvx' = 265.00 psi  (CSI = 0.47)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
9/12/2021 5
ΔLL = = 0.25 in.
(L/d)LL = 120.96 / 0.25 = 489
 ΔLL = 0.25 in = L/489 < L/480   ➜  OK
ΔTL = = 0.31 in.
(L/d)TL = 120.96 / 0.31 = 386
 ΔTL = 0.31 in = L/386 < L/360   ➜  OK
fc⊥ = = 254.1 psi
 fc⊥ = 254.1 psi < Fc⊥x' = 650.00 psi  (CSI = 0.39)   ➜  OK
9/12/2021 6
