Beam Design - Joists
Design Span (L): 8.00 ft.
Clear Span: 7.83 ft.
Total Span: 8.17 ft.
Bearing (lb): 2 in.
Live Load: 40 plf
Dead Load: 10 plf
Selfweight: 20.7 lbs
Dist. Selfweight: 2.58 plf
Total Weight: 21.1 lbs
CL Beam Stability Factor 0.859 - - - - -
Beam Design Mark Plog 23515 SE 282nd Pl Kay
9/9/2021 1
9/9/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (95.99 + 2)] x (12 in./ft.)3 = 0.62 ft3
Volumespan = N[A x L] = 1 x [10.88 x 95.99] x (12 in./ft.)3 = 0.60 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.62 = 21.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.60 = 20.7 lbs
40 plf
10 plf
ws = 2.58 plf
7.83 ft.
8.17 ft.
214.69 lbs
214.69 lbs
9/9/2021 3
lu = Unbraced Length = 7.999 ft.
lu/d = = 13.24
le = 1.63lu + 3d = 1.63(96.0) + 3(7.25) = 178.21 in. = 14.85 ft.  (NDS Table 3.3.3)
Rb = = 23.96
 Rb = 23.96 < 50   ➜  OK
9/9/2021 4
FbE = = 1212.05 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.00)(1)(1)(1.2)(1)(1) = 1080.00 psi
CL =   = 0.859
Fbx' = (900)(1.00)(1)(1)(0.859)(1.2)(1)(1) = 928.2 psi
fb = = 384.1 psi
 fb = 384.1 psi < Fbx' = 928.2 psi  (CSI = 0.41)   ➜  OK
fv* = = 24.63 psi
 fv* = 24.63 psi < Fvx' = 180.00 psi  (CSI = 0.14)   ➜  OK
fv = = 29.01 psi
 fv = 29.01 psi < Fvx' = 180.00 psi  (CSI = 0.16)   ➜  OK
9/9/2021 5
ΔLL = = 0.05 in.
(L/d)LL = 95.99 / 0.05 = 1986
 ΔLL = 0.05 in = L/1986 < L/360   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 95.99 / 0.06 = 1510
 ΔTL = 0.06 in = L/1510 < L/240   ➜  OK
fc⊥ = = 71.6 psi
 fc⊥ = 71.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.11)   ➜  OK
9/9/2021 6
