Beam Design - (2) 2x8, 5, span
Design Span (L): 5.00 ft.
Clear Span: 4.83 ft.
Total Span: 5.17 ft.
Bearing (lb): 2 in.
Live Load: 320 plf
Dead Load: 80 plf
Selfweight: 25.8 lbs
Dist. Selfweight: 5.17 plf
Total Weight: 26.7 lbs
Beam Design Mark Plog 23515 SE 282nd Pl Kay
9/9/2021 1
9/9/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (60.00 + 2)] x (12 in./ft.)3 = 0.78 ft3
Volumespan = N[A x L] = 2 x [10.88 x 60.00] x (12 in./ft.)3 = 0.76 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.78 = 26.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.76 = 25.8 lbs
320 plf
80 plf
ws = 5.17 plf
5.00 ft.
4.83 ft.
5.17 ft.
1046.68 lbs
1046.68 lbs
9/9/2021 3
lu/d = = 3.31
Rb = = 6.31
 Rb = 6.31 < 50   ➜  OK
9/9/2021 4
FbE = = 17475.73 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.00)(1)(1)(1.2)(1)(1) = 1080.00 psi
CL =   = 0.997
Fbx' = (900)(1.00)(1)(1)(0.997)(1.2)(1)(1) = 1076.5 psi
fb = = 578.1 psi
 fb = 578.1 psi < Fbx' = 1076.5 psi  (CSI = 0.54)   ➜  OK
fv* = = 52.97 psi
 fv* = 52.97 psi < Fvx' = 180.00 psi  (CSI = 0.29)   ➜  OK
fv = = 69.86 psi
 fv = 69.86 psi < Fvx' = 180.00 psi  (CSI = 0.39)   ➜  OK
9/9/2021 5
ΔLL = = 0.03 in.
(L/d)LL = 60.00 / 0.03 = 2032
 ΔLL = 0.03 in = L/2032 < L/360   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 60.00 / 0.04 = 1605
 ΔTL = 0.04 in = L/1605 < L/240   ➜  OK
fc⊥ = = 174.4 psi
 fc⊥ = 174.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.28)   ➜  OK
9/9/2021 6
