Beam Design - solar
Grade: SPF No.2
Live Load: 61.6 plf
Dead Load: 8.75 plf
Selfweight: 19.6 lbs
Dist. Selfweight: 1.67 plf
Total Weight: 20.0 lbs
Beam Design d f sl leeham
9/9/2021 1
9/9/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (141.00 + 3)] x (12 in./ft.)3 = 0.69 ft3
Volumespan = N[A x L] = 1 x [8.25 x 141.00] x (12 in./ft.)3 = 0.67 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.69 = 20.0 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.67 = 19.6 lbs
61.6 plf
8.75 plf
ws = 1.67 plf
432.10 lbs
432.10 lbs
9/9/2021 3
Fbx' = (875)(1.15)(1)(1)(1)(1.3)(1)(1) = 1308.1 psi
fb = = 1972.1 psi
 fb = 1972.1 psi > Fbx' = 1308.1 psi  (CSI = 1.51)   ➜  NG
9/9/2021 4
fv* = = 70.93 psi
 fv* = 70.93 psi < Fvx' = 155.25 psi  (CSI = 0.46)   ➜  OK
fv = = 76.93 psi
 fv = 76.93 psi < Fvx' = 155.25 psi  (CSI = 0.50)   ➜  OK
9/9/2021 5
ΔLL = = 0.91 in.
(L/d)LL = 141.00 / 0.91 = 155
 ΔLL = 0.91 in = L/155 > L/360   ➜  NG
ΔTL = = 1.06 in.
(L/d)TL = 141.00 / 1.06 = 133
 ΔTL = 1.06 in = L/133 > L/240   ➜  NG
fc⊥ = = 96.0 psi
 fc⊥ = 96.0 psi < Fc⊥x' = 425.00 psi  (CSI = 0.23)   ➜  OK
9/9/2021 6
