Grade: SPF No.2
Live Load: 133 plf
Dead Load: 20 plf
Selfweight: 25.8 lbs
Dist. Selfweight: 2.20 plf
Total Weight: 26.4 lbs
Beam Design 2021A517
9/8/2021 1
9/8/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (141.00 + 3)] x (12 in./ft.)3 = 0.91 ft3
Volumespan = N[A x L] = 1 x [10.88 x 141.00] x (12 in./ft.)3 = 0.89 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.91 = 26.4 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.89 = 25.8 lbs
Distributed Self Weight (ws) = = 2.20 plf
133 plf
20 plf
ws = 2.20 plf
931.18 lbs
931.18 lbs
9/8/2021 3
Fbx' = (875)(1.15)(1)(1)(1)(1.2)(1)(1) = 1207.5 psi
fb = = 2445.9 psi
 fb = 2445.9 psi > Fbx' = 1207.5 psi  (CSI = 2.03)   ➜  NG
9/8/2021 4
fv* = = 112.83 psi
 fv* = 112.83 psi < Fvx' = 155.25 psi  (CSI = 0.73)   ➜  OK
fv = = 125.76 psi
 fv = 125.76 psi < Fvx' = 155.25 psi  (CSI = 0.81)   ➜  OK
9/8/2021 5
ΔLL = = 0.86 in.
(L/d)LL = 141.00 / 0.86 = 165
 ΔLL = 0.86 in = L/165 > L/360   ➜  NG
ΔTL = = 1.00 in.
(L/d)TL = 141.00 / 1.00 = 141
 ΔTL = 1.00 in = L/141 > L/240   ➜  NG
fc⊥ = = 206.9 psi
 fc⊥ = 206.9 psi < Fc⊥x' = 425.00 psi  (CSI = 0.49)   ➜  OK
9/8/2021 6
