Design Span (L): 5.25 ft.
Clear Span: 5.00 ft.
Total Span: 5.50 ft.
Live Load: 562 lbs
Dead Load: 15 lbs
Selfweight: 13.6 lbs
Dist. Selfweight: 2.58 plf
Total Weight: 14.2 lbs
Beam Design 2021A512
9/8/2021 1
9/8/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (63.00 + 3)] x (12 in./ft.)3 = 0.42 ft3
Volumespan = N[A x L] = 1 x [10.88 x 63.00] x (12 in./ft.)3 = 0.40 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.42 = 14.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.40 = 13.6 lbs
562 lbs
15 lbs
ws = 2.58 plf
5.25 ft.
5.00 ft.
5.50 ft.
295.60 lbs
295.60 lbs
9/8/2021 3
fb = = 699.7 psi
 fb = 699.7 psi < Fbx' = 1242.0 psi  (CSI = 0.56)   ➜  OK
9/8/2021 4
fv* = = 40.51 psi
 fv* = 40.51 psi < Fvx' = 207.00 psi  (CSI = 0.20)   ➜  OK
fv = = 40.73 psi
 fv = 40.73 psi < Fvx' = 207.00 psi  (CSI = 0.20)   ➜  OK
9/8/2021 5
ΔLL =   =   = 0.04 in.
(L/d)LL = 63.00 / 0.04 = 1640
 ΔLL = 0.04 in = L/1640 < L/360   ➜  OK
ΔTL =   =   = 0.04 in.
(L/d)TL = 63.00 / 0.04 = 1574
 ΔTL = 0.04 in = L/1574 < L/240   ➜  OK
fc⊥ = = 65.7 psi
 fc⊥ = 65.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.11)   ➜  OK
9/8/2021 6
