Size: 4 x 12
Design Span (L): 3.13 ft.
Clear Span: 3.00 ft.
Total Span: 3.25 ft.
Bearing (lb): 1.5 in.
Live Load: 986 plf
Dead Load: 505 plf
Selfweight: 29.2 lbs
Dist. Selfweight: 9.35 plf
Total Weight: 30.4 lbs
CF Size Factor 1.1 1 - 1 - -
Beam Design BLIGHT
1/16/2021 1
Beam Design BLIGHT
1/16/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (37.50 + 1.5)] x (12 in./ft.)3 = 0.89 ft3
Volumespan = N[A x L] = 1 x [39.38 x 37.50] x (12 in./ft.)3 = 0.85 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.89 = 30.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.85 = 29.2 lbs
986 plf
505 plf
ws = 9.35 plf
3.13 ft.
3.00 ft.
3.25 ft.
2438.07 lbs
2438.07 lbs
Beam Design BLIGHT
1/16/2021 3
fb = = 297.7 psi
 fb = 297.7 psi < Fbx' = 1138.5 psi  (CSI = 0.26)   ➜  OK
Beam Design BLIGHT
1/16/2021 4
fv* = = 35.72 psi
 fv* = 35.72 psi < Fvx' = 207.00 psi  (CSI = 0.17)   ➜  OK
fv = = 89.31 psi
 fv = 89.31 psi < Fvx' = 207.00 psi  (CSI = 0.43)   ➜  OK
Beam Design BLIGHT
1/16/2021 5
ΔLL = = 0.00 in.
(L/d)LL = 37.50 / 0.00 = 11777
 ΔLL = 0.00 in = L/11777 < L/360   ➜  OK
ΔTL = = 0.00 in.
(L/d)TL = 37.50 / 0.00 = 7740
 ΔTL = 0.00 in = L/7740 < L/240   ➜  OK
Ab = b x lb = 3.5 x 1.5 = 5.25 in2
fc⊥ = = 464.4 psi
 fc⊥ = 464.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.74)   ➜  OK
Beam Design BLIGHT
1/16/2021 6
