Design Span (L): 6.17 ft.
Clear Span: 6.00 ft.
Total Span: 6.33 ft.
Bearing (lb): 2 in.
Live Load: 230 plf
Dead Load: 23 plf
Selfweight: 15.9 lbs
Dist. Selfweight: 2.58 plf
Total Weight: 16.4 lbs
Incised Lumber: Yes
Beam Design 2021A506
9/7/2021 1
9/7/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (74.00 + 2)] x (12 in./ft.)3 = 0.48 ft3
Volumespan = N[A x L] = 1 x [10.88 x 74.00] x (12 in./ft.)3 = 0.47 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.48 = 16.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.47 = 15.9 lbs
230 plf
23 plf
ws = 2.58 plf
6.17 ft.
6.33 ft.
809.39 lbs
809.39 lbs
9/7/2021 3
Fbx' = (900)(1.00)(1)(1)(1)(1.2)(0.8)(1.15) = 993.6 psi
fb = = 1109.6 psi
 fb = 1109.6 psi > Fbx' = 993.6 psi  (CSI = 1.12)   ➜  NG
9/7/2021 4
Fvx' = (180)(1.00)(1)(1)(0.8) = 144.00 psi
fv* = = 87.40 psi
 fv* = 87.40 psi < Fvx' = 144.00 psi  (CSI = 0.61)   ➜  OK
fv = = 108.70 psi
 fv = 108.70 psi < Fvx' = 144.00 psi  (CSI = 0.75)   ➜  OK
9/7/2021 5
ΔLL = = 0.10 in.
(L/d)LL = 74.00 / 0.10 = 716
 ΔLL = 0.10 in = L/716 < L/360   ➜  OK
ΔTL = = 0.11 in.
(L/d)TL = 74.00 / 0.11 = 644
 ΔTL = 0.11 in = L/644 < L/240   ➜  OK
fc⊥ = = 269.8 psi
 fc⊥ = 269.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.43)   ➜  OK
9/7/2021 6
