Beam Design - MR
Grade: SP DSS
Design Span (L): 14.75 ft.
Clear Span: 14.50 ft.
Total Span: 15.00 ft.
Selfweight: 124.7 lbs
Dist. Selfweight: 8.46 plf
Total Weight: 126.9 lbs
Beam Design CARLOS REYES 54 FOREST PL ROCHELLE PK. NJ 1234
9/7/2021 1
SP DSS 2200 1550 175 660 1850 1900000 690000 0.55
9/7/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (177.00 + 3)] x (12 in./ft.)3 = 3.40 ft3
Volumespan = N[A x L] = 3 x [10.88 x 177.00] x (12 in./ft.)3 = 3.34 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 3.40 = 126.9 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 3.34 = 124.7 lbs
Distributed Self Weight (ws) = = 8.46 plf
ws = 8.46 plf
14.75 ft.
14.50 ft.
15.00 ft.
1375.93 lbs
1375.93 lbs
9/7/2021 3
Fbx' = (2200)(1.15)(1)(1)(1)(1)(1)(1) = 2530.0 psi
fb = = 1518.7 psi
 fb = 1518.7 psi < Fbx' = 2530.0 psi  (CSI = 0.60)   ➜  OK
9/7/2021 4
fv* = = 57.11 psi
 fv* = 57.11 psi < Fvx' = 201.25 psi  (CSI = 0.28)   ➜  OK
fv = = 62.21 psi
 fv = 62.21 psi < Fvx' = 201.25 psi  (CSI = 0.31)   ➜  OK
9/7/2021 5
ΔLL = = 0.39 in.
(L/d)LL = 177.00 / 0.39 = 451
 ΔLL = 0.39 in = L/451 < L/360   ➜  OK
ΔTL = = 0.72 in.
(L/d)TL = 177.00 / 0.72 = 246
 ΔTL = 0.72 in = L/246 < L/240   ➜  OK
fc⊥ = = 101.9 psi
 fc⊥ = 101.9 psi < Fc⊥x' = 660.00 psi  (CSI = 0.15)   ➜  OK
9/7/2021 6
