Beam Design - MR
Design Span (L): 14.75 ft.
Clear Span: 14.50 ft.
Total Span: 15.00 ft.
Quantity (N): 4
Selfweight: 152.4 lbs
Dist. Selfweight: 10.33 plf
Total Weight: 155.0 lbs
Beam Design CARLOS REYES 54 FOREST PL ROCHELLE PK. NJ 1234
9/7/2021 1
9/7/2021 2
Volumetotal = N[A x (L + lb)] = 4 x [10.88 x (177.00 + 3)] x (12 in./ft.)3 = 4.53 ft3
Volumespan = N[A x L] = 4 x [10.88 x 177.00] x (12 in./ft.)3 = 4.46 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.53 = 155.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 4.46 = 152.4 lbs
Distributed Self Weight (ws) = = 10.33 plf
ws = 10.33 plf
14.75 ft.
14.50 ft.
15.00 ft.
1389.99 lbs
1389.99 lbs
9/7/2021 3
fb = = 1150.7 psi
 fb = 1150.7 psi < Fbx' = 1242.0 psi  (CSI = 0.93)   ➜  OK
9/7/2021 4
fv* = = 43.27 psi
 fv* = 43.27 psi < Fvx' = 207.00 psi  (CSI = 0.21)   ➜  OK
fv = = 47.13 psi
 fv = 47.13 psi < Fvx' = 207.00 psi  (CSI = 0.23)   ➜  OK
9/7/2021 5
ΔLL = = 0.35 in.
(L/d)LL = 177.00 / 0.35 = 507
 ΔLL = 0.35 in = L/507 < L/360   ➜  OK
ΔTL = = 0.65 in.
(L/d)TL = 177.00 / 0.65 = 273
 ΔTL = 0.65 in = L/273 < L/240   ➜  OK
fc⊥ = = 77.2 psi
 fc⊥ = 77.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.12)   ➜  OK
9/7/2021 6
