Size: 8.75 x 12
Live Load: 280 plf
Dead Load: 210 plf
Selfweight: 289.3 lbs
Dist. Selfweight: 24.62 plf
Total Weight: 295.4 lbs
Load Duration: 1.25
Beam Design 2021A50
1/16/2021 1
b = 8.750 in.
A = 8.750 x 12.000 = 105.00 in.2
Sx = (8.750)(12.000)2/6 = 210.00 in.3
Sy = (8.750)2(12.000)/6 = 153.13 in.3
Ix = (8.750)(12.000)3/12 = 1260.00 in.4
Iy = (8.750)3(12.000)/12 = 669.92 in.4
Beam Design 2021A50
1/16/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [105.00 x (141.00 + 3)] x (12 in./ft.)3 = 8.75 ft3
Volumespan = N[A x L] = 1 x [105.00 x 141.00] x (12 in./ft.)3 = 8.57 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 8.75 = 295.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 8.57 = 289.3 lbs
Distributed Self Weight (ws) = = 24.62 plf
280 plf
210 plf
  ws = 24.62 plf
3087.71 lbs
3087.71 lbs
Beam Design 2021A50
1/16/2021 3
Fbx' = (2400)(1.25)(1)(1)(1.0) = 3000.0 psi
fb = = 507.5 psi
 fb = 507.5 psi < Fbx' = 3000.0 psi  (CSI = 0.17)   ➜  OK
Beam Design 2021A50
1/16/2021 4
fv* = = 35.84 psi
 fv* = 35.84 psi < Fvx' = 331.25 psi  (CSI = 0.11)   ➜  OK
fv = = 43.19 psi
 fv = 43.19 psi < Fvx' = 331.25 psi  (CSI = 0.13)   ➜  OK
Beam Design 2021A50
1/16/2021 5
ΔLL = = 0.05 in.
(L/d)LL = 141.00 / 0.05 = 2663
 ΔLL = 0.05 in = L/2663 < L/360   ➜  OK
ΔTL = = 0.10 in.
(L/d)TL = 141.00 / 0.10 = 1449
 ΔTL = 0.10 in = L/1449 < L/240   ➜  OK
Ab = b x lb = 8.75 x 3 = 26.25 in2
fc⊥ = = 117.6 psi
 fc⊥ = 117.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.18)   ➜  OK
Beam Design 2021A50
1/16/2021 6
