Grade: DF SS
Design Span (L): 12.04 ft.
Clear Span: 11.75 ft.
Total Span: 12.33 ft.
Bearing (lb): 3.5 in.
Live Load: 350 plf
Dead Load: 100 plf
Selfweight: 96.5 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 98.9 lbs
Lateral Support: 4' o/c
Beam Design 2021A5
1/3/2021 1
Beam Design 2021A5
1/3/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (144.49 + 3.5)] x (12 in./ft.)3 = 2.89 ft3
Volumespan = N[A x L] = 2 x [16.88 x 144.49] x (12 in./ft.)3 = 2.82 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.89 = 98.9 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.82 = 96.5 lbs
350 plf
ws = 8.02 plf
12.04 ft.
12.33 ft.
2824.28 lbs
2824.28 lbs
Beam Design 2021A5
1/3/2021 3
lu = Unbraced Length = 4 ft.
lu/d = = 4.27
Rb = = 11.12
 Rb = 11.12 < 50   ➜  OK
Beam Design 2021A5
1/3/2021 4
FbE = = 6699.03 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1500)(1.15)(1)(1)(1)(1)(1) = 1725.00 psi
CL =   = 0.983
Fbx' = (1500)(1.15)(1)(1)(0.983)(1)(1)(1) = 1696.2 psi
fb = = 1574.1 psi
 fb = 1574.1 psi < Fbx' = 1696.2 psi  (CSI = 0.93)   ➜  OK
fv* = = 103.47 psi
 fv* = 103.47 psi < Fvx' = 207.00 psi  (CSI = 0.50)   ➜  OK
fv = = 122.56 psi
 fv = 122.56 psi < Fvx' = 207.00 psi  (CSI = 0.59)   ➜  OK
Beam Design 2021A5
1/3/2021 5
ΔLL = = 0.24 in.
(L/d)LL = 144.49 / 0.24 = 590
 ΔLL = 0.24 in = L/590 < L/360   ➜  OK
ΔTL = = 0.32 in.
(L/d)TL = 144.49 / 0.32 = 451
 ΔTL = 0.32 in = L/451 < L/240   ➜  OK
fc⊥ = = 269.0 psi
 fc⊥ = 269.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.43)   ➜  OK
Beam Design 2021A5
1/3/2021 6
