Beam Design - MR
Design Span (L): 14.75 ft.
Clear Span: 14.50 ft.
Total Span: 15.00 ft.
Selfweight: 114.3 lbs
Dist. Selfweight: 7.75 plf
Total Weight: 116.2 lbs
Orientation: Horizontal
Beam Design 1234
9/7/2021 1
Beam Design 1234
9/7/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (177.00 + 3)] x (12 in./ft.)3 = 3.40 ft3
Volumespan = N[A x L] = 3 x [10.88 x 177.00] x (12 in./ft.)3 = 3.34 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.40 = 116.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.34 = 114.3 lbs
Distributed Self Weight (ws) = = 7.75 plf
ws = 7.75 plf
14.75 ft.
14.50 ft.
15.00 ft.
1370.62 lbs
1370.62 lbs
Beam Design 1234
9/7/2021 3
Fby' = (900)(1.15)(1)(1)(1)(1.2)(1.15)(1)(1) = 1428.3 psi
fb = = 7312.1 psi
 fb = 7312.1 psi > Fby' = 1428.3 psi  (CSI = 5.12)   ➜  NG
Beam Design 1234
9/7/2021 4
fv* = = 60.92 psi
 fv* = 60.92 psi < Fvy' = 207.00 psi  (CSI = 0.29)   ➜  OK
fv = = 61.97 psi
 fv = 61.97 psi < Fvy' = 207.00 psi  (CSI = 0.30)   ➜  OK
Beam Design 1234
9/7/2021 5
ΔLL = = 10.88 in.
(L/d)LL = 177.00 / 10.88 = 16
 ΔLL = 10.88 in = L/16 > L/360   ➜  NG
ΔTL = = 19.89 in.
(L/d)TL = 177.00 / 19.89 = 9
 ΔTL = 19.89 in = L/9 > L/240   ➜  NG
Ab = d x lb = 7.25 x 3 = 21.75 in2
fc⊥ = = 21.0 psi
 fc⊥ = 21.0 psi < Fc⊥y' = 625.00 psi  (CSI = 0.03)   ➜  OK
Beam Design 1234
9/7/2021 6
