Beam Design - MARTINEZ RESIDENCE
Size: 4 x 10
Design Span (L): 13.83 ft.
Clear Span: 13.58 ft.
Total Span: 14.08 ft.
Selfweight: 106.4 lbs
Dist. Selfweight: 7.69 plf
Total Weight: 108.3 lbs
Load Duration: 1.25
Beam Design 211030
9/7/2021 1
Beam Design 211030
9/7/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [32.38 x (166.00 + 3)] x (12 in./ft.)3 = 3.17 ft3
Volumespan = N[A x L] = 1 x [32.38 x 166.00] x (12 in./ft.)3 = 3.11 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.17 = 108.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.11 = 106.4 lbs
ws = 7.69 plf
13.83 ft.
13.58 ft.
14.08 ft.
1286.41 lbs
1286.41 lbs
Beam Design 211030
9/7/2021 3
lu/d = = 2.59
Rb = = 6.11
 Rb = 6.11 < 50   ➜  OK
Beam Design 211030
9/7/2021 4
FbE = = 18643.40 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.25)(1)(1)(1.2)(1)(1) = 1350.00 psi
CL =   = 0.996
Fbx' = (900)(1.25)(1)(1)(0.996)(1.2)(1)(1) = 1344.8 psi
fb = = 1050.6 psi
 fb = 1050.6 psi < Fbx' = 1344.8 psi  (CSI = 0.78)   ➜  OK
fv* = = 52.02 psi
 fv* = 52.02 psi < Fvx' = 225.00 psi  (CSI = 0.23)   ➜  OK
fv = = 58.54 psi
 fv = 58.54 psi < Fvx' = 225.00 psi  (CSI = 0.26)   ➜  OK
Beam Design 211030
9/7/2021 5
ΔLL = = 0.22 in.
(L/d)LL = 166.00 / 0.22 = 744
 ΔLL = 0.22 in = L/744 < L/240   ➜  OK
ΔTL = = 0.41 in.
(L/d)TL = 166.00 / 0.41 = 407
 ΔTL = 0.41 in = L/407 < L/180   ➜  OK
fc⊥ = = 122.5 psi
 fc⊥ = 122.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.20)   ➜  OK
Beam Design 211030
9/7/2021 6
