Beam Design - MARTINEZ RESIDENCE
Size: 4 x 8
Selfweight: 70.8 lbs
Dist. Selfweight: 6.03 plf
Total Weight: 72.3 lbs
Load Duration: 1.25
Beam Design 211030
9/7/2021 1
Beam Design 211030
9/7/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (141.00 + 3)] x (12 in./ft.)3 = 2.11 ft3
Volumespan = N[A x L] = 1 x [25.38 x 141.00] x (12 in./ft.)3 = 2.07 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.11 = 72.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.07 = 70.8 lbs
ws = 6.03 plf
1086.16 lbs
1086.16 lbs
Beam Design 211030
9/7/2021 3
lu/d = = 3.31
Rb = = 5.41
 Rb = 5.41 < 50   ➜  OK
Beam Design 211030
9/7/2021 4
FbE = = 23786.41 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.25)(1)(1)(1.3)(1)(1) = 1462.50 psi
CL =   = 0.997
Fbx' = (900)(1.25)(1)(1)(0.997)(1.3)(1)(1) = 1457.7 psi
fb = = 1222.7 psi
 fb = 1222.7 psi < Fbx' = 1457.7 psi  (CSI = 0.84)   ➜  OK
fv* = = 56.40 psi
 fv* = 56.40 psi < Fvx' = 225.00 psi  (CSI = 0.25)   ➜  OK
fv = = 62.87 psi
 fv = 62.87 psi < Fvx' = 225.00 psi  (CSI = 0.28)   ➜  OK
Beam Design 211030
9/7/2021 5
ΔLL = = 0.24 in.
(L/d)LL = 141.00 / 0.24 = 585
 ΔLL = 0.24 in = L/585 < L/240   ➜  OK
ΔTL = = 0.44 in.
(L/d)TL = 141.00 / 0.44 = 323
 ΔTL = 0.44 in = L/323 < L/180   ➜  OK
fc⊥ = = 103.4 psi
 fc⊥ = 103.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.17)   ➜  OK
Beam Design 211030
9/7/2021 6
