Beam Design - MARTINEZ RESIDENCE
Size: 4 x 12
Selfweight: 109.9 lbs
Dist. Selfweight: 9.35 plf
Total Weight: 112.2 lbs
Load Duration: 1.25
CF Size Factor 1.1 1 - 1 - -
Beam Design 211030
9/7/2021 1
Beam Design 211030
9/7/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (141.00 + 3)] x (12 in./ft.)3 = 3.28 ft3
Volumespan = N[A x L] = 1 x [39.38 x 141.00] x (12 in./ft.)3 = 3.21 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.28 = 112.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.21 = 109.9 lbs
ws = 9.35 plf
1106.12 lbs
1106.12 lbs
Beam Design 211030
9/7/2021 3
lu/d = = 2.13
Rb = = 6.74
 Rb = 6.74 < 50   ➜  OK
Beam Design 211030
9/7/2021 4
FbE = = 15329.02 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.25)(1)(1)(1.1)(1)(1) = 1237.50 psi
CL =   = 0.996
Fbx' = (900)(1.25)(1)(1)(0.996)(1.1)(1)(1) = 1232.1 psi
fb = = 517.1 psi
 fb = 517.1 psi < Fbx' = 1232.1 psi  (CSI = 0.42)   ➜  OK
fv* = = 34.68 psi
 fv* = 34.68 psi < Fvx' = 225.00 psi  (CSI = 0.15)   ➜  OK
fv = = 41.26 psi
 fv = 41.26 psi < Fvx' = 225.00 psi  (CSI = 0.18)   ➜  OK
Beam Design 211030
9/7/2021 5
ΔLL = = 0.06 in.
(L/d)LL = 141.00 / 0.06 = 2184
 ΔLL = 0.06 in = L/2184 < L/240   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 141.00 / 0.12 = 1185
 ΔTL = 0.12 in = L/1185 < L/180   ➜  OK
fc⊥ = = 105.3 psi
 fc⊥ = 105.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.17)   ➜  OK
Beam Design 211030
9/7/2021 6
