Size: 5.5 x 18
Design Span (L): 14.10 ft.
Clear Span: 13.85 ft.
Total Span: 14.35 ft.
Live Load: 425 lbs
Dead Load: 8563.7 lbs
Selfweight: 327.4 lbs
Dist. Selfweight: 23.21 plf
Total Weight: 333.2 lbs
CL Beam Stability Factor 0.962 - - - - -
CV Volume Factor 0.992b - - - - -
Beam Design 2021A490
8/28/2021 1
d = 18.000 in.
8/28/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [99.00 x (169.25 + 3)] x (12 in./ft.)3 = 9.87 ft3
Volumespan = N[A x L] = 1 x [99.00 x 169.25] x (12 in./ft.)3 = 9.70 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 9.87 = 333.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 9.70 = 327.4 lbs
425 lbs
8563.7 lbs
  ws = 23.21 plf
14.10 ft.
13.85 ft.
14.35 ft.
4660.93 lbs
4660.93 lbs
8/28/2021 3
lu = Unbraced Length = 14.104 ft.
lu/d = = 9.40
le = 1.37lu + 3d = 1.37(169.2) + 3(18) = 285.87 in. = 23.82 ft.  (NDS Table 3.3.3)
Rb = = 13.04
 Rb = 13.04 < 50   ➜  OK
8/28/2021 4
FbE = = 5996.32 psi
CL =   = 0.962
CV = = 0.992
CL = 0.962 < CV = 0.992
Fbx' = (2400)(1.15)(1)(1)(0.962) = 2654.6 psi
fb = = 1303.9 psi
 fb = 1303.9 psi < Fbx' = 2654.6 psi  (CSI = 0.49)   ➜  OK
fv* = = 70.05 psi
8/28/2021 5
 fv* = 70.05 psi < Fvx' = 304.75 psi  (CSI = 0.23)   ➜  OK
fv = = 70.58 psi
 fv = 70.58 psi < Fvx' = 304.75 psi  (CSI = 0.23)   ➜  OK
ΔLL =   =   = 0.01 in.
(L/d)LL = 169.25 / 0.01 = 18970
 ΔLL = 0.01 in = L/18970 < L/360   ➜  OK
ΔTL =   =   = 0.19 in.
(L/d)TL = 169.25 / 0.19 = 877
 ΔTL = 0.19 in = L/877 < L/240   ➜  OK
8/28/2021 6
fc⊥ = = 282.5 psi
 fc⊥ = 282.5 psi < Fc⊥x' = 650.00 psi  (CSI = 0.43)   ➜  OK
8/28/2021 7
