Design Span (L): 14.50 ft.
Clear Span: 14.00 ft.
Total Span: 15.00 ft.
Live Load: 90 plf
Dead Load: 8.5 plf
Selfweight: 58.1 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 60.1 lbs
Beam Design xx
1/15/2021 1
Beam Design xx
1/15/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (174.00 + 6)] x (12 in./ft.)3 = 1.76 ft3
Volumespan = N[A x L] = 1 x [16.88 x 174.00] x (12 in./ft.)3 = 1.70 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.76 = 60.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.70 = 58.1 lbs
90 plf
8.5 plf
ws = 4.01 plf
14.50 ft.
15.00 ft.
768.81 lbs
768.81 lbs
Beam Design xx
1/15/2021 3
fb = = 1021.7 psi
 fb = 1021.7 psi < Fbx' = 1035.0 psi  (CSI = 0.99)   ➜  OK
Beam Design xx
1/15/2021 4
fv* = = 57.52 psi
 fv* = 57.52 psi < Fvx' = 207.00 psi  (CSI = 0.28)   ➜  OK
fv = = 66.06 psi
 fv = 66.06 psi < Fvx' = 207.00 psi  (CSI = 0.32)   ➜  OK
Beam Design xx
1/15/2021 5
ΔLL = = 0.31 in.
(L/d)LL = 174.00 / 0.31 = 554
 ΔLL = 0.31 in = L/554 < L/360   ➜  OK
ΔTL = = 0.36 in.
(L/d)TL = 174.00 / 0.36 = 486
 ΔTL = 0.36 in = L/486 < L/240   ➜  OK
fc⊥ = = 85.4 psi
 fc⊥ = 85.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.14)   ➜  OK
Beam Design xx
1/15/2021 6
