Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Selfweight: 110.2 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 112.2 lbs
Beam Design 2021A483
8/28/2021 1
8/28/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (165.00 + 3)] x (12 in./ft.)3 = 3.28 ft3
Volumespan = N[A x L] = 2 x [16.88 x 165.00] x (12 in./ft.)3 = 3.22 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.28 = 112.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.22 = 110.2 lbs
ws = 8.02 plf
13.75 ft.
13.50 ft.
1281.12 lbs
1281.12 lbs
8/28/2021 3
fb = = 820.2 psi
 fb = 820.2 psi < Fbx' = 1035.0 psi  (CSI = 0.79)   ➜  OK
8/28/2021 4
fv* = = 48.30 psi
 fv* = 48.30 psi < Fvx' = 207.00 psi  (CSI = 0.23)   ➜  OK
fv = = 55.92 psi
 fv = 55.92 psi < Fvx' = 207.00 psi  (CSI = 0.27)   ➜  OK
8/28/2021 5
ΔLL = = 0.14 in.
(L/d)LL = 165.00 / 0.14 = 1168
 ΔLL = 0.14 in = L/1168 < L/180   ➜  OK
ΔTL = = 0.26 in.
(L/d)TL = 165.00 / 0.26 = 638
 ΔTL = 0.26 in = L/638 < L/120   ➜  OK
fc⊥ = = 142.3 psi
 fc⊥ = 142.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.23)   ➜  OK
8/28/2021 6
