Size: 6.75 x 24
Design Span (L): 12.75 ft.
Clear Span: 12.50 ft.
Total Span: 13.00 ft.
Live Load: 1282 plf
Dead Load: 285 plf
Selfweight: 484.3 lbs
Dist. Selfweight: 37.98 plf
Total Weight: 493.8 lbs
Lateral Support: 4' o/c
CV Volume Factor 0.954b - - - - -
Beam Design 2021A482
8/28/2021 1
b = 6.750 in.
d = 24.000 in.
A = 6.750 x 24.000 = 162.00 in.2
Sx = (6.750)(24.000)2/6 = 648.00 in.3
Sy = (6.750)2(24.000)/6 = 182.25 in.3
Ix = (6.750)(24.000)3/12 = 7776.00 in.4
Iy = (6.750)3(24.000)/12 = 615.09 in.4
8/28/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [162.00 x (153.00 + 3)] x (12 in./ft.)3 = 14.63 ft3
Volumespan = N[A x L] = 1 x [162.00 x 153.00] x (12 in./ft.)3 = 14.34 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 14.63 = 493.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 14.34 = 484.3 lbs
Distributed Self Weight (ws) = = 37.98 plf
1282 plf
285 plf
  ws = 37.98 plf
12.75 ft.
12.50 ft.
13.00 ft.
10432.38 lbs
10432.38 lbs
8/28/2021 3
lu = Unbraced Length = 4 ft.
lu/d = = 2.00
Rb = = 7.22
 Rb = 7.22 < 50   ➜  OK
8/28/2021 4
FbE = = 19583.40 psi
CL =   = 0.992
CV = = 0.954
CV = 0.954 < CL = 0.992
Fbx' = (2400)(1.15)(1)(1)(0.954) = 2633.4 psi
fb = = 604.0 psi
 fb = 604.0 psi < Fbx' = 2633.4 psi  (CSI = 0.23)   ➜  OK
fv* = = 65.02 psi
8/28/2021 5
 fv* = 65.02 psi < Fvx' = 304.75 psi  (CSI = 0.21)   ➜  OK
fv = = 94.74 psi
 fv = 94.74 psi < Fvx' = 304.75 psi  (CSI = 0.31)   ➜  OK
ΔLL = = 0.05 in.
(L/d)LL = 153.00 / 0.05 = 2809
 ΔLL = 0.05 in = L/2809 < L/360   ➜  OK
ΔTL = = 0.07 in.
(L/d)TL = 153.00 / 0.07 = 2244
 ΔTL = 0.07 in = L/2244 < L/240   ➜  OK
8/28/2021 6
fc⊥ = = 515.2 psi
 fc⊥ = 515.2 psi < Fc⊥x' = 650.00 psi  (CSI = 0.79)   ➜  OK
8/28/2021 7
